Steering wheels???
  • Steering wheels???
    I'm trying to change a small turbo to big turbo steering,
    Can anyone tell me if the back of a st wheel fits on to a bt?
    This
    Not sure about that, but I know the ST has a airbag. I have seen people putting the standard airbag wheel back on and needing a part associated with the airbag as well to go in.
      PS you selling you ST wheel? PM me a price please
        The yellow wire does go to the airbag which is why I think I need the same part but for a BT wheel as the plug on the end of the yellow wire won't feed through the steering wheel.
          Yeah will sell the st wheel as soon as I get the BT wheel to fit.
          Ill pm you as soon as I got it sorted mate
            Also I'm sure I've got some wires missing from the BT wheel.
            I'm sure I need 2 wired to go to the black part that fits to the rear of the wheel then 2 wire to the horn but I only have 2 wires.
              The steering column is different between bt and st (the hex is a different size); so you'll have to change that as well I'm afraid!
                I have what you need
                  http://www.escortrscosworth.com/foru...ad.php?t=31668
                    will I not need the plastic part in my first post if I get the correct column?
                      No need to change the Hex shaft,
                      they are the same size for airbag and non airbag
                        Sorry to jump on your thread but what do I need to get a 3 spoke turbo wheel on starting to lover these
                          This type
                            Yes
                              Where you get those from Cosmo would like a 4 spoke one day
