450hp engine spec question?
  • 450hp engine spec question?
    Hi
    A friend of mine want to build a 450-500hp engine.
    Which.spec would you recommend?
    He has a std block with 10000miles to start.
    Thx for help
    ESCOS rebuilt / http://www.escortrscosworth.com/foru...ad.php?t=30193
      What's the car being used for?
        He use it on the street
          Buy my engine low mileage 491bhp with Autronic management. Will be cheaper and just as good
            More to the point - what budget and what transmission does the car have?
            If a 4x4 on a standard transmission, I'd be going for a CR Turbos T38 (which keeps the torque around the 370lb ft mark at 27psi) and will achieve the 450bhp figure. To get 500bhp requires the transmission being upgraded and a completely different spec turbo.
              How much would this cost? I would like a 500bhp engine!
                Love it!!
                  It's for sale in his engine for sale thread lol
                    Hi.
                    He has a quaife gearbox. Not the dogbox...
                    Thx
                      I will supply the engine with alternator, power steering pump, turbo, manifolds, etc and the Autronic management with a specially made loom from Ryan Looms for £6500 so it's ready to bolt in and drive basically. You would just need a 4x4 sump as mine runs a 2wd one, but you can sell the sump for £150 odd
                        Anne I've got a 4x4 sump you can have cheap lol!
                          6500k for 500 horses sounds good! But what else needs uprating? Transmission etc?
                            This used to be in a friends 3dr and is a top spec engine
                            Would cost double that from any top tuner to do
                              Ideally a decent spec gearbox (I would use the Pete Doughty box) and front diff strengthening plate is all I would do rear diff if your gonna do launches
                              Thanks Daz, it is a good strong engine
