Compression Strut kit
Cheers bud that does help i only use mine for road so might aswell spend my money else whereOriginally posted by Gatecrasher View PostGood mod depending on what cars used for, road car no track rally yes but it's not as simple as just the comp strut kit as you will with have to up the spring rates on the car to compensate fir no anti roll bar or add a front mounted round bar bladed anti roll bar... Hope that helps
The reason i was looking at them was because ive done the tracking on mine its all poly bushed and also on coilovers but still does'nt feel right at the front end its hard to explain. One thing i have noticed is when im on full lock left or right you can hear the front springs twanging if you know what i mean cheersOriginally posted by Gatecrasher View PostDefiantly spend your money else where
what are you trying to achieve with the car? Is there somthing your not quiet happy with or just interested in modding the car to make it do somthing better?
If you're doing track work, the first thing to do with the suspension is fit a 6° rear beam.....Mike Rainbird
Then I can't understand why you would even be considering the compression strutsOriginally posted by 360bhp-rs-turbo View PostNo bud not using for track, road only
What suspension do you run and what setting did you have when the tracking was done?Originally posted by 360bhp-rs-turbo View PostThe reason i was looking at them was because ive done the tracking on mine its all poly bushed and also on coilovers but still does'nt feel right at the front end its hard to explain. One thing i have noticed is when im on full lock left or right you can hear the front springs twanging if you know what i mean cheers
