Right then, mates 4x4 Cossie got parked up after a good run out, with no problems at all.
Tried to move the car, and it won't go forwards or backwards more than a few feet? Brakes are not seized.
With the front wheels jacked up, they turn in opposite directions freely, but after 3-4 turns the diff seems to go solid, & won't freely turn unless you force it?
I think this points to the front diff, as the centre prop does not need to turn to let the front wheels turn against each other?
What's caused this do you think? Tooth off or lack of oil? Or is there anything else that could cause this?
