ALS valve
  • ALS valve
    Hi
    As above where i get an ALS valve?
    Thx for help
    ESCOS rebuilt / http://www.escortrscosworth.com/foru...ad.php?t=30193
    No such thing :/
    Als uses the idle control valve,
    Or buy a remote icv and use that
      Originally posted by Boostjunky View Post
      No such thing :/
      Yes i mean the als with the idle control valve
      Where can i get one?
      Thx
        Thx
        You already have 1 fitted mate :/
          The standard idle valve is not an ALS valve, however it can be used as one as all you need is an air bypass of the throttle body, a proper ALS valve is a heavily modified idle valve with a top had style plunger and a modified throttle body which will give you proper ALS
            Ah i see jimbo!
            I have a spare remote 12mm bosch bypass calve i want to use instead of my iscv so i could possibly use my std iscv so i can jave a decent cold start again
            Is this possible...!
              Hi jim
              Yes i have such a idle valve.. but mine is damahed.. wjere can i het a new one?
              Thx
                Hi jim
                Thx
                Ah ok, I'm not sure where you will find one we did used to make them ourselves but there is so much work involved we don't anymore as we only have a hand lathe no cnc!
                Ah i see jimbo!
                Yes but not on webber as it won't control an idle map and an ALS map
                I run a 25mm bypass valve for ALS and have idle as I'm on t6 2000
                  heres one
                    anyone got a spare top hat to make one of these or measurements so i can do my own?
                      Ill measure this up for you mate
                        i have such a spare top... what they modfi on a std. idle? somebody has the measurements?
                        thx
