Boost problems ongoing
  • Boost problems ongoing
    Had problems with boost
    On off etc.
    Changed most of the vacume hoses,changed plugs,rotor arm,cap etc.
    Then there is some kind of solenoid valve on top of intercooler in front of turbo
    When I tried to take the hoses off it came apart in my hand
    Just taken down the road and its worse now than before
    Boost will only go half way up the gauge and no more
    I have also changed fuel filter
    Any ideas please
    And anyone know what this valve does
    It has 2 vacume hoses to it and a multi plug
    It's the Amal valve and used to control boot.
    Scouse.
      Is there any way of testing it
        Just had a look on ebay and they all have 3 hoses going to them and mine only has 2
        Mines a bt escos if that makes any difference
          It's a lectron value boyo
            Hi buddy so an idea what it does
            Will it affect the boost pressure
              Yes, it controls the boost.
              http://www.escortrscosworth.com/foru...ad.php?t=30057
                Cheers for that
                I'll have to get on the case
                  I had roughly the same problem 3 weeks ago. Take the amal valve yellow cap head off and remove the spring and piston inside out (careful, it'll jump out) and clean with electrical cleaner. Then reassemble, should be ok after. Mine clicked fine, but was just sticky.
                    Don't have any electrical cleaner
                    Would wd40 do the job or just knacker it
                      Yup, will be fine. Doesn't need much, just enough to loosen all the crap inside. Use a cotton bud on a stick to poke through the ports to ensure its nice and clean. But remember, the spring will pop out once you've prised the cap off....so don't loose anything!
                        if its broken or the case is cracked etc then that will most likely be your boost problem as its losing boost pressure all the time
                            http://s1155.photobucket.com/user/ch...tml?sort=3&o=0
                              [/URL]
