Afternoon guys, is anyone on here clued up/ hetas qualified for solid fuel wet systems?.
I'm linking up my current solid fuel heating system upto a combi boiler.
I'm doing this via a heat exchanger so the rad circuit stays pressurised and the solid fuel side stays open vented.
The system was spec'd by a hetas guy via stoves online website.
Now I need it fitted ASAP the fitter I rang said it doesn't sound safe as one heat leak rad may not be enough to stop the system boiling in the event of a power cut losing the pumps.
The only thing I can think is that I didn't make it clear that the solid fuel system is staying open vented? It will have a large capacity copper header tank also.
Here's the schematic I have for the system
Thanks for any feed back. I'm running out of time as I need this done by mid September. I may have to just fit the combi and tie in the wood burner when winter is over.
