escos wont start
  • Tech Question - escos wont start
    hi guys escos lrge turbo wont start. fuel pump primes getting spark and fuel just turns over but wont fire uphttp://www.escortrscosworth.com/forum/images/smilies/Headbang.gif
    Firing order correct?
    Scouse.
      timing and firing order etc all fine new sensors on nearly everthing, thinking now it must be fusebox or ecuhttp://www.escortrscosworth.com/forum/images/smilies/Headbang.gif
        has it just happened or have you done any work on it?
          recent engine rebuild stopped working after about 200 miles couple o months ago. new starter, ignition coil, leads, amplifier, rotor arm and cap, most sensors from tdc to map/air/temp/tps etc. was running after rebuild just a bit tight expected after rebuild tho. just started to splutter one day then died and wont start since.
            Can you turn it over by hand at the crank bolt?
            Scouse.
              Do you have good fuel pressure should be 3.5 bars
                Also check the inner wing multi plug
                  yeah it turns over by hand scouse!
                  fuel pressure is spot on too! mark
                  multiplug seems ok getting feed from all sensors to ecu!!
                  might have to trailer to ford garage but dont think theyre that clued up on cossies (my local one anyway)
                    You are sure it got spark and fuel?
                      yeah spark to all plugs and 3.2-3.5 bar fuel pressure!!
                        Fuel pressure dosen`t tell if it got fuel out of injectors
                          cant see all 4 injectors being blocked surely if it was just one it would fire up
                            Are sparks plugs wet after trying start it? If not, injectors may not opening
                              theyre more damp than wet ( i mean not soaking) like its not getting enough!!
                              would that be electrical or sticky injectors!!
                              any way of testing them?
