Engine builders HELP
  • Engine builders HELP
    Iv a VW pd engine here now the engine was lying outside for afew weeks with a busted sump, it seams the bores have started to rust, now the engine turn half way round an locked, iv the glow plugs out, is there anything I could spray into the bores to say free it up? or is it for the bin? thanks Andrew
    diesel... if it turns and then stop the you should find out were the problem is...
      Is it hitting valves? Timed right?
      Thanks Mark.
      NORRISMOTORSPORT 01773836274
      WWW.NI-FORDS.CO.UK
