I own a 2008 RRS HSE TDV8.
As title says, when the suspension is in normal mode and select access mode the front begins to lower then as the back starts it immediately stops and goes into raised mode, and says suspension fault then asks you to lower when you are clear of the obstacle.
The only way I can get the car to lower is to drive above the speed which automatically lowers back to standard.
There also seems to be a height difference of about 10-20mm between o/s to n/s.
Then tonight I had a new one which a red warning came up on the dash with the message "fault do not exceed 30mph"
Then when I returned home the front was sitting at 830mm (floor to arch) & rear was 900mm.
Just wandering if anyone could shed some light on any of theses problems I have or advise where would be best to take it in the Glasgow area?
