T4 Turbo
  • T4 Turbo
    Hi guys,
    I'm going to fit this setup soon:
    T4 hyrbid turbo (A/R .70 compressor and A/R 68 turbine) and 44mm external wastegate.
    Together with a suited manifold ofcourse.
    The thing is, i know it will need a lot of headwork to flow more air the T4 can deliver... And i will be up for the job, but right now, my old T34.63 stock turbo died (bearings) and i need a replacment item..
    Soooo.. i figured, why not put this setup on, a map to suit and just run about 0,7bar boost untill the big engine work can be done in a couple of months..
    Would it be OK to drive it like that? (further specs are: RS500 cooler, wrc multilayer gasket, ARP bolts, MSD 380+ chip, 3" exhaust,..
    Love to hear your input on this guys!!
    Jimbo is the man for the correct answer mate
      I put a t4 on my saph std engine and it made 430 bhp. Went like fuck to lol only thing I had was a 500 intercooler.
      Thanks Mark.
      NORRISMOTORSPORT 01773836274
      WWW.NI-FORDS.CO.UK
        Yeah It can be done, just needs a good map and set up, I prefer them on air injectors really at this sort if spec.
        Regards James.
        www.autodynamix.co.uk
        www.shop.autodynamix.co.uk
          I had a t4 with greys on one of my escorts and went well on and off track.
          standard engine btw.
            Been there and done it with a RB T4 and it was not all that, what you need is a Borg Warner EFR twin scroll and it will boost up better than a t34 with much more power. Do it once and of it right is what I have learnt
              Correct, Just about every hybrid turbo I have seen have been junk and can never match for all round performance of a correctly chosen standard turbo.
                Cheers for the replies!!!
                So Cossie Col & Mark Shead, you guys say i should not go for this setup with hybrid T4?
                  that's what it says.
                    Sorry to jump in, but could you use a BW EFR turbo with standard manifold or does that need to be twin scroll to match?
                      It doesn't fit and needs either a complete new manifold or a new link pipe. The manifold makes a massive diff.
                        To make a t4 work well you need to spec the engine very well, yourmStd comp is good, but cams, headwork, inlet manifold and the biggest thing cam timing will make or break a t4 engine.
                        I personally wouldn't put that turbo on your engine, even for a stop gap as it will be lazy, flat and pretty boring. I also wouldn't suggest using that chip so the cost of a map to suit is needed. Hope this helps
                          Lover of the old school Paul lol
                            Cheers Jimbo!!
                              Nothing wrong with an old school T4.
