techies
  • techies
    im after buying a new wireless router for the home,what do i need as i have no idea on these,any recomendations?
    Had BT round for a line fault and got a free home hub thingy......seems ok, result
    They all seem to do the same thing so don't really understand what the advantage of one is over another
      Linksys been fine for me
        sometimes the signal doesnt seem very good in some places of the house but im like you,i have no idea what makes a good one ?
          Who's your provider? I'm with virgin media and use their super hub and it seems good throughout the house
            im with virgin,ive got a belkin at the moment
              Speak to them about their super hub upgrade
                is it free? or is it gonna cost me?
                  Something here for people to look at regarding wireless routers and if it helps them then great
                  1. Optimize wireless router location
                  Probably the easiest and most important improvement you can make is physically moving your router. Try a centralized location in your home. If it’s a two story home with a basement, put the router in the middle of the home on the first floor. Keep it away from devices that can interfere with a wireless signal, like a microwave or cordless phone. Also keep it away from foundational walls and out of cabinets. Don’t shove it at the bottom of an AV rack stuffed with home theater equipment or in your utility room. Your ultimate goal is to maximize coverage in the home by keeping the router away from things that might block or otherwise interfere with the signal. Try out a few different locations and then walk around your home with a wireless device and see how the signal changes.
                  Each time you move the router, you will want to record what the signal strength is and perform a speed test. This allows you to be more precise and strategic about the process, particularly in later parts of this guide. You can test the signal strength simply by observing how many bars your device shows. For those wanting the most accurate results possible, consider downloading the program inSSIDer. It allows you to see the wireless channel and signal strength of all of the wireless networks within range.
                  2. Hard wire as much as possible
                  This is a pretty simple suggestion. The fewer devices on a wireless network, the faster the network is likely to run. Not to mention that a hardwired connection is faster and more reliable in the first place. This process may involve moving some of your equipment around so you can get an Ethernet cable to it from the router. If you know your way around CAT cabling, you might check to see if the phone lines in your home are wired using CAT 5 or CAT 6. If they are, you could use the phone cables throughout your home to hard wire devices (heck, even CAT 3 can be made to work). You might also consider using an Ethernet over powerline adapter explained in our article on how to add wireless to hardwired devices.
                  3. Disable old wireless protocols
                  Even though your fancy new router may be super-fast with 802.11n (or even 802.11ac), as soon as a device connects using an older protocol, say, 802.11g, the entire network slows down. The fix to this problem is to set the router to only broadcast newer wireless modes. For your reference, the speeds from slowest to fastest are: b, g, n, ac. Notice in the picture below that you can select which modes you want the router to work with.
                  wireless protocal g/n
                  Disable Old Wireless Modes
                  If all of the devices on your network support wireless n (802.11ac is faster, but most devices don’t support it yet), then select “802.11n only”. Unfortunately, this will kick any devices not compatible with wireless n off of the network. You can either:
                  A) stop using the older devices.
                  B) upgrade their wireless cards, if possible.
                  C) hardwire them to the router instead of connecting wirelessly.
                  D) select a mixed operation mode (like 802.11g + n), or E) purchase a dual band router.
                  Dual band routers are like having two routers built into one (close enough, anyway). They can broadcast two separate wireless networks simultaneously. This means that you could setup a wireless g network for you older devices, and a wireless n network for newer devices. This allows the older devices to connect to WiFi without slowing down newer devices. But don’t get too excited yet. Dual band routers operate by sending out the two wireless networks on different frequencies, one at 2.4Ghz, the other at 5Ghz. Many new wireless devices still do not work on a 5Ghz network, even if the device is 802.11n compatible. Additionally, 5Ghz wireless networks have poorer range than 2.4Ghz networks. You will want to do some research to find out which devices of yours actually support 5Ghz before investing in a dual band router. With that said, if you are planning on buying a new router anyway, go with a dual band router.
                  4. Use WPA2 security only
                  WEP encryption used to be the standard when it came to wireless security. However, now it’s not only a poor form of protection, but it can limit the speed of your network. The same goes for the more modern WPA standard. If possible, you should limit your router to only work with WPA2 encryption.
                  wpa2 security only
                  Wireless Encryption Settings
                  5. Change the wireless channel
                  You’re certainly not the only person on the block with wireless internet and routers only operate on a limited number of channels. Multiple routers operating on the same channel can cause all sorts of issues, including dropping a wireless signal all together.
                  First, go to an area you normally have wireless problems. If there aren’t any real problem areas, just move a few rooms away from the router. Before changing anything, test the signal strength and speed, like you did when determining the best location for the router. This gives us a baseline and allows us to gauge the effects of any change we make.
                  wireless channel
                  Wireless Channel Setting
                  Most routers set the channel to “auto” by default. Find the channel setting in the router menu, and select the lowest option (CH 1 for 2.4gHz networks), then go back and check the signal strength and speed again. Repeat this process with a few different channels. I typically only test the lowest, middle, and highest channels. Once you have found the channel that gives you the best performance, select it and save the settings.
                  6. Change channel width
                  As wireless protocols have advanced, one of the ways they have increased speed is by operating using wider wireless channels. Wireless n routers need to use a 40Mhz channel width in order to achieve maximum speed. Most routers come with 20MHz as the default width, this is in an attempt to avoid interference. So, there is a potential for this change to negatively affect some users. If you start to notice issues, switch back to a 20Mhz operation. Also note that this isn’t really for increasing how fast you browse the internet, this change is more likely to be evident when streaming/transferring files between devices on your network.
                  Simply find the “Channel Width” setting in your router’s setting and change it to “Auto 20/40MHz”.
                  wireless channel width
                    Just ring up complaining about the connection and they may well just put you on superhub.
                    Think that's what my old dear did
                      cheers chaps
                        one more question,if i buy a new virgin superhub can i set it up and just use it straight off or do i need to register it with virgin or something first?
                          Why buy it? As long as you know the settings to use it (password, username etc. you can get these fron virgin anyway) then you should be ok.
                          Scouse.
                            i thought if i just buy one it will be loads easier than trying to get one off virgin? they charge around £75 and i can get one for a fraction of that,just found out that they are locked and virgin wont unlock them unless you are the orig owner,damn
                              if you are happy to stay with them nick,just ring them up and tell em your leaving for bt or sky they will give you incentives to stay. when i had it installed they tried to charge me £50 installation fee, i rang the day before they were due and cancelled so they waived it and i stayed lol
