Hi all just a little update on the Cosworth engine cossiedave came around on Saturday & removed the engine & stripped it down to find the No 4 shells had spun & welded its self to crank shaft
So after a chat with Dave we have come up with a plan to rebuild the Engine to a higher spec
6 long studs
Mountune WRC head gasket
Mahle pistons with valve cut outs
Polish & ported head
High pressure oil pump
Regrind & balance crank
MK Motorsport alloy pulleys a full set
I will keep you updated with the build inc some pictures
SO a big thank you to cossiedave for all advice & i am looking forward to see what magic he can do
Cheers Paul
6 long studs
Cheers Paul
