I need some help regarding my idling speed on my st model please.
Starting the car up from cold, the car is idling at 1200 - 1500 rpm for some time before it will drop down to 900 rpm. Once the car is warm the car continuous to idle at 1200 - 1500 rpm for some time before it drops back to 900 rpm. Sometimes the car will idle at 2000rpm and it will not drop down to 900 rpm
If I disconnect the the multi plug from the back of the ISCV the car will idle nicely at 900 rpm.
I have removed and cleaned the ISCV, removed the throttle body and cleaned that up, the throttle body flap is fully closed when the car is idling as well. I'm unable to find any form of air leaks in the system.
Is it possible the ISCV needs replacing? or is it something else.
