Are they the same as the Escort Cosworth? The ones I'm looking at do have abs sensor holes and they look very similar to me.....
Sierra 4x4 Front hubs
Ah, okay mate, thanks for that. If I could get this driveshaft out of the hub it wouldn't be an issue, but it's now snapped off a couple of my pulling tools. Any ideas how I can remove it? It's stuck solid. The other side came off as easy as anything with a puller.Originally posted by Ginge View Post4x4 cosworth ones are Trev but the 2.0L 4x4 ones have a different caliper offset
Maybe I should take the assembly to a garage and give them the grief.
Put your puller on the hub. Apply a bit of tension and apply some penetrating oil and leave it for a few hours. Go back and give it a half turn and reapply if necessary.
Or bite the bullet and nip down to your local garage and ask them.
It won't come off guys. The shaft is knackered now but it still won't move a muscle from the hub, the end's so fat now I don't even know whether it will come out anyway.Originally posted by Paul Cos View PostPut your puller on the hub. Apply a bit of tension and apply some penetrating oil and leave it for a few hours. Go back and give it a half turn and reapply if necessary.
I've got one of my cars in for it's Mot on Monday so might take it down to the garage and see if they've got a press or can get some heat on it or something. I'm getting nowhere. Knocked one of the studs out by accident while trying but it will not move even a millimetre.
You're not kidding. I could win on one of those things at the fairground where you wield a big hammer and try and make the thing hit the bell at the top, the amount of hammering I've been doing.Originally posted by The Radman View Postsounds well and truly stuck then trev
and knackered now
Hi,
Not sure if you have already tried these pullers.
I have used these tools to remove wheel hubs from a driveshaft after going through the same issue you've had. they just bolt onto the hub and centre nut/bolt will push the driveshaft out, remove everything else from the hub except for shock/suspension.
http://www.ebay.co.uk/itm/Otc-Tools-...#ht_1435wt_986
https://www.google.co.uk/shopping/pr...=0CCUQ8wIwADgo
As others have said already tighten up the puller, spray / soak with WD40, leave for 1hr and tighten the puller again and repeat.
You could also try to put everything back loosely, refit the wheel and roll the car slowly back and forward to load up the hub/driveshaft a little and then remove everything and try again.
good luck mate.
thx,
Manoj
