I'm just going with the standard stuff now guys, I've repainted all of mine myself and even painted my Konis black and stickered them up. They look pretty good I think.
So what's your thoughts on tweaking the rear roll centre and/or dialling out some pro-squat ?
im not a suspension guru, i personally dont see the gains in rose jointing the outer arm and my reasoning behind this is a large adjustment on the outer makes a very small change to the toe. where on the inner arm it needs a small amount to match said change.
but the large outer change does make a different to set back. hence why our beam has always been the same as ahmed's beam. fixed set back and camber/toe adjustable on one rose joint on the inner arm.
