Rebuilding my Ecos and forgot which side does the shortest drive shaft go, at minute I have the shortest one on drivers side
Drive shafts?
Originally posted by hughy View PostYea inside the front diff on drivers side? Should this be put in or can I get away without it? I've read about this before but been a long time ago
im sure it there to stop the shaft popping out under load
a lot of people buy the automotiveunlimited dear but abit longer and stronger
front shafts should be same length
the clip isnt important it can be left of but dead easy just to take the diff pan off and refit
xr4x4 shafts are aproxx 14mm longer than cossy ones im talking of the actual shaft part only the ends are the same
are you measureing the whole thing hughy ?? cus you may need to compress the spring inside the pot joint on both and re measure
you do not need to fit the circlip the inner cv tripod will pop out of the inner cv long before the shaft falls out of the diff
.steve
NSSCC 2016 Class B1 Champion
