I currently have Ap 6pot upfront with a 362mm grooved disc. The rear discs and calipers are standard. What larger size rear discs can be fitted whilst keeping the oe rear caliper? Would like some with the grooves in to match the front if possible. Thanks
What size rear discs...
Keep to the 300mm rotors and bells at the rear with standard 4x4 calipers, anything like 4 pots on the back for a road car and you're just asking for trouble when you hit the brake.sigpic
Yes Mark at Grove advised me this also when the car was there last. So will keep the standard calipers just want some bigger discs to match the frontsOriginally posted by Cochyn View PostKeep to the 300mm rotors and bells at the rear with standard 4x4 calipers, anything like 4 pots on the back for a road car and you're just asking for trouble when you hit the brake.
Thanks, Jamie
Perfect thank you , and look spot on. Will get these orderedOriginally posted by Mark King View PostREYLAND do a 325mm now
http://www.reyland.co.uk/4x4-rear-kits/
Thanks, Jamie
