Computer God Required....HELP
  • Computer God Required....HELP
    I have a PC still running windows XP
    I have an issue of when I boot the PC up I get a box pop up saying c:\Program Files\Search Extensions/client.exe missing
    Any computer wiz kids able to help me with this issue
    RSOC Member 16886
    Darren Parker
    07539-936944
    Turn it off and turn it on again...
    ..sorry!
      Already done that
      RSOC Member 16886
      Darren Parker
      07539-936944
        http://answers.microsoft.com/en-us/w...d-b261b328a7e1
          All resolved
          RSOC Member 16886
          Darren Parker
          07539-936944
            First off XP is a very good OS if it's not broken don't fix it.
            The only other OS I would use is win 7.
            I would download and install super anti spyware and let it do a full scan as you might have some malware software on there.
            Only use the free version that's good enough.
            http://www.superantispyware.com
            I use this and it's spot on.
              Sounds like you have / had some malware, you could try using something like malwarebytes (https://www.malwarebytes.org/), problem is with most of these anti malware programs is they sometimes find the bad files and remove them but don't always find the / fix the registry entries that are created to run them when you boot the computer up (hence the error messages), and they won't find something that was only invented yesterday by some kid on the other side of the world, by the time they have written a definitions file that can deal with it its too late, you've already been infected!
              Go to Start menu, select Run (or press the Windows Key and R on the keyboard), then type in: msconfig (then press Enter or OK button)
              Go to the Startup tab, then look in the command column for your "c:\Program Files\Search Extensions/client.exe", un-tick the box in the startup column for that line then click apply, then reboot and it *should* not give you the error message.
