Not sure if this is the right place to post this here but here goes.. After putting my car back together I can't get it to fire, it's on an l8 ecu 83lbs injectors wasted spark, iv got a good spark, injectors are getting a signal checked using a noid, 40psi fuel pressure when I'm cranking it over, removed injectors and cranked over and they are fireing but for some reason the plugs are not getting damp? Any ideas. All sensors are new and gapped correctly, as is the complete ignition system,I'm thinking ecu or chip fault? Even tho they were working before. Also the engine caught fire that's why it was pulled apart, no damage to loom as iv checked it.
Last attempt before I take it to a specialist ... Or scrap yard!
