turbos
  • turbos
    Hi all what different turbo's are you using as i'm looking to upgrade from my t38 cheers
    What are you looking for.
      turbo
      don't know my t38 needs a rebuild so i thought i would go for a newer and roller bearing turbo
        Upgrade do you want more power or better response of both,
        For me the BW Efr turbo and manifold is the way to go but costs more.
          both
          my spec is
          200 Block long studed
          Standard Head
          TT T38
          Grey Injectors
          S/S Exhaust
          MSD Mapped
          Air Injector
          what turbo would you recomend and i'm looking at cam what power could i get
          cheers
            both
            my spec is
            Standard Head
            TT T38
            Grey Injectors
            S/S Exhaust
            MSD Mapped
            Air Injector
            cheers
            I have seen 468hp on a standard engine with a EFR7064 to run this you would need bigger injectors, What is your current hp.
              turbo
              when it was mapped i was told about 420
              it all so has a 2wd exhaust manifold
                The improvements are easy to make but will cost more than sticking to a normal spec turbo that you can get a chip for.
                The diff would be night and day but so would cost.
                  turbo
                  ok would i need different injectors? can you give me a price and what i would need
                  what cams can i use on standerd engine?
                  have you used HOLSET HY35 turbo as a friend has a new one
                  cheers
                    cheers
                    I have not tried the Holset so I cant give you any feed back on it,
                    As I don't map the stock ecu for me to do it you would need a diff Ecu and the costs it brings.
                      ok
                      ok cheers
                        turbonetics e50 stage 3-5? if they can still be bought...
                        garrett, gt3071
                          I'm on a T28 so not much use
                            Why not fit a billet wheel to your T38 ?
                              I'd get the T38 rebuilt GT30 is to laggy for my liking.
