Any ideas what's causing my car to over fuel so bad?
a head job(porting++) is to make the head flow more air, so Will need more fuel on same pressure(mapsensor) since much more air Will go into cylinders on all rpm. so if then you put on a Stock head you Will get allot less air into the cylinders att the same pressure in innlet, but still feed just as much fuel in, causing it to overfuel.
same With turbo but not so much effect if "similar" turbo, but Will make some diffrence since resistance and air flow..
very basic told, but you get the point?
Get the point but the only difference in head work I meant was one head was a ported head by nms and the new head is touring car spec by nick waples so imagine their going to be different but not as much a difference as standard to say 500hp spec. It's best for me to get a temporary chip then to my exact spec is best?
so many things can make differences though, cam timing being one,
if it was me, id want to do the job in 2 parts at that spec, get the car in and check diagnostics and set up, then map it a base to allow you to run in on, then bring it back once done for some boost.
what inlet manifold is it on?
Originally posted by James @ M Developments View Postso many things can make differences though, cam timing being one,
