Potential orders for 18 inch escoz replica wheels
  • Think my name went down by accident? : )
    • I would need 5 wheels as the boot would not look right with a space saver spare.
      • Of the 39 names, it would be interesting to see what wheels will be made redundant as a result of these?
        I'm guessing mostly Ronnies
        • My ronnies won't be going anywhere
          Not many unrefurbed sets about
          • RSCosworthman,
            I have done the measuring I offered to do.
            Started another thread for the 18x9 details to avoid polluting this one too much.
            http://www.escortrscosworth.com/foru...ad.php?t=45587
            Basically 18x9 ET25 works for me and would be my preferred choice.
            ET20 will work on OEM geometry.
            John
            EsCos - Turning dinosaurs into smiles.
            • Can you add my name to the list please?
              Thank you
              Nathan
              • Originally posted by ossie cossie View Post
                I think 5 is a good idea if it's an option
                • Gotta be worth getting more made than actually needed as there will always be someone wanting a replacement for a damaged one or new owners may want a set later on.........that's assuming you have somewhere to store a few wheels of course
                  If there good you'll never be stuck with them if you want rid anytime Plus will always be buyers who don't use the forum.......they will know about them eventually as word gets around....
                  • I have a pic of a set on a sapphire.
                    • Originally posted by jsa View Post
                      Hi John, once again thanks for your outstanding measurement work as you explained in detail in the other post. By now I've read (and hopefully understood) everything you did.
                      Given the quote above and the stuff I read in the other post I just want to be 100% sure: 18x9 ET25 will also work on OEM geometry right?
                      Or does this also require the small
                      Then my preference would also be to go for 18x9 ET25.
                      If we decide on this as a group that we all want this, I can finalize the design over the coming week.
                      p.s. list below updated - just let me know if anyone wants a set of 5
                      18x9J inch delivered! New (and probably last) batch being produced as we speak - se posts here
                      • Originally posted by rscosworthman View Post
                        There is a reason why 99% of people running 9x18" have ET20, its simply because it fits best. ET25 will sit further in, causing a lot more trouble in the spring cup area. Look at my post in between all the measurements in the other thread... If you get them made in ET25 I'm pretty sure most would need a 5mm spacer at the front in addition to modifying spring cup (unless using coilovers).
                        • Please put me down for a set
                          Neil
                          • p.s. list below updated - just let me know if anyone wants a set of 5[/QUOTE]
                            5 for me please
                            • I will have 5 please
                              Sent from my iPhone using Tapatalk
                              • I`ll defo want the 5 set
                                Bob
                                Escort RS Cosworth Owner
