Fuel lines
  • Fuel lines
    Guys,
    Ive recently bought new re-manufactured fuel lines (which i need to get my finger out and arrange pickup)
    i want to have -6 ends brazed on to these so the rest can be done in aero on the fuel system, can anyone recommend someone who can do this service.
    I dont like seeing aero lines ran down the floor pan hence why im going down this route
    Cheers Rob
    Hi mate just out of curiosity, where did you get the remanufactured lines from, and how much were they?
    I'm in process of doing underbody resto and will need some new ones soon.
    Regards Mat
      make them yourself out of 8mm fuel line easily sourced
        I bought them off a guy on here, think there is a guy on ebay that makes them also, I got them for a good price other than that I would have made my own
          Regards Mat
          http://www.ebay.co.uk/itm/Escort-Cos...item27d88ef418
            Trev at Stage 1 is the same e-bay seller, go direct and cut out the middle man
              So can anyone weld/braze -6 fittings onto these
                Instead of brazing a fitting on the end how about a short piece of drilled hexagonal metal either stainless or aluminium with the correct threads tapped in each end, the -6 (9/16 unf) male fitting sealed with a crush washer, the fuel pipe end maybe the same or at bottom of tapped hole (metric ?) as standard.
                Steve
                  Go to you nearest pirtek/pipe centre, they will do it
                  CheeRS Shaun,
                  SCS MAPPED 482 BHP 400 lb ft
                    Steve
                    Steve,
                    I think i'm with you on that but i'm also sure that the lines are same as original steel on outside and copper internally, I just thought fittings brazed/welded would be the easiest and less chance of leakage
                      You could use cliplock to AN adapters.
                      John
                        Any links to these adapters
                          Think these will work, i'll phone torques pretty much sure they will have something
                          http://www.ebay.co.uk/itm/6-AN6-STRA...item2563e3e684
                            No links sorry. I just know they are made by a couple AN hose manufactuers to adapt from ford oem lines to AN.
                            A google search for ford push lock AN adapters, returns plenty hits.
                            http://www.google.com.au/search?biw=...55.7JoJGy1-BDs
                            John
                              Must be the ones in above link
