No oil pressure!
  • No oil pressure!
    While driving home from the pod yesterday my oil pressure suddenly dropped to nothing, pulled over to save engine and called aa. Any ideas before I rip it apart? It's a new build only done 150 miles on a new protech pump. Sure iv read a thread about these protech pumps failing? Its a 2wd saff.
    Sorry to hear that mate.
    Sounds like another knackered protech oil pump ,
    but worth removing the dizzy, to see if the dizzy to pump driveshaft is still in one piece, if broken it will cause the pump to stop working.
    Best of luck and good that you spotted it early.
      Thanks mate bit of a nightmare after a 5 year rebuild! Certainly looks like oil pump but am going to remove the dizzy to check drive, that was new too tho but you never know.
        Have you got spray jets in the block or on the pump
          Jesus lee that's fuckin shit news mate hope your motors ok if you want any help getting motor out and sorting quick give me a bell it's just bad news that sorry mate .........
            Gutted for you mate !!!
            BTCC Trakstar 1991 - Returned 2014
            http://www.sapphirerscosworth.com/forums/
              What main bearings u got? I had a problem years ago, fitted fully grooved acl race mains and the pump couldn't produce enough pressure to run them
              CheeRS Shaun,
              SCS MAPPED 482 BHP 400 lb ft
                What a load of shit
                  It's a nightmare mate more bad luck again! I had a chat with Dave Pritchard earlier and he said to check distributor and drive first so fingers crossed now! Thanks, il give u a call if I need help hopefully it won't have to come out!
                    I know Carl, nightmare again this car continues to test me!
                      Can't remember exactly what bearings but was recommended them il have to look through my receipts. It's only don't 150 miles and was fine until yesterday on way home from pod, just hope it's simple fix and no damage, I did switch it straight off.
                        not good...
                        protecpump is most likly the problem, they have failed allot off them...
                        have to agree With cossiedavid, no bearing can have anything to do With loos of oilpressure, if they are not gone...
                          I had exact same issue with shells supplied by woodford garage
                          Grooved on both bearings so oil pressure couldnt build up they should be smooth one side and grooved the other
                          And before people start shouting i know some engines are built like that and work ok but im telling you now some dont and if you look in the osworth build manual it ststes it all in there and they designed the bloody thing
                          But im sure someone will still argue
                          But dont bother cus im mot realy interesting in arguing its judt an expeitience ive had
                          And mine drove about 150 miles before it lost oil pressure
                          So if its not the dissy drive check the shells thats All im saying
                            its strange, but maybe... but protec pumps have failed allot... so would change it, but the 4x4 pump is the worst... but maybe his 2wd pumps is no good either..
                              Just had a look through photos and the bearings are grooved one side only, I remembered this but just double checked.
                              So hopefully it's not that.
