Body Shell
  • Body Shell
    I am after a bit of advice please.
    I have just purchased a brand new right hand drive unused ford escort cosworth motor sport 909 body shell fitted with a roll cage. What is required to get a V5 for this shell. There is no serial numbers on the shell except for the 909 tag.
    I also have a used ford motorsport 909 shell registered as an escort cosworth on 1988 on the V5, can I get this transferred over to the new body shell. if not what is the old shell worth with the V5, it has slight damage to the floor pans but I have replacements ready to fit.
    COZZFATHER might be your man for this
      ooh 909
        Pictures of the new shell
          Nicedid you buy this in ireland.
            Why the grill pattern in the front footwells ?
            John
              Nice!!
              11.6 @ 121 MPH
                All cosworths have it under the factory sound deadening
                  I'm pretty sure if you are replacing with a brand new shell then you can transfer the ID
                    I have seen brand new shells,they are black..
                    Well unless they were trimmed painted in which case they were white
                      yes however surely this has been sprayed to preserve the welding done when fitting the cage and doing the welding ect....
                        I'm somewhat baffled as to why that would be the case.
                        John
                          yeah bought it from a guy in ireland.
                            Found out I can transfer the ID across, so that now leaves me the question what is my old shell worth with no ID.
                              Don't know why either,you do realise that's just the inner panel though
