thought we would build something a little different, been a bit hush as was revealed at classic ford show at pod.
so a lot have already seen it heres some pics, big thanks to dave as couldn't of done it without him.
quick spec
4x4 cosy front chassis legs with inner wings modified to fit, also 4x4 cosy tunnel strut top moved out all to try and look as factory as poss.
one off made rear end and tubed.
coil overs 6 deg rear beam shortened prop pde gearbox 6 paddle clutch. 500 bhp spec engine autronics ecu with cdi 1000 id injectors hart inlet custom inter cooler and rad tubular manifold borg warner 70/64 efr custom made exhaust one off spec r tanks retrim in blasck leather with green stitching image split rims and a lot more
quick spec
