need help if you can anyone have an issue with fiesta 1.4 tdci help ??
any good ford auto electricians on here not cossie
Originally posted by Mark Barber View Postneed help if you can anyone have an issue with fiesta 1.4 tdci help ??sigpic
ok heres my issue
bought the car with starter motor failure
fitted new starter car started but wouldnt rev
pluged bosch scanner in to read ecu but no comms
as i was sat in the car with engine running all the lights on the dash came on everything as if id just turned the ign on with out engine running so everythin on
so turned it off to see if it did it again when i restarted but
nothing engine immobiliser kicked in so immob light flashing no crank
no feed to injectors or nothing
and cant communicate with ecu
cant even re program a key with my key ptogrammer no comms with that either
checked all fuses and earths
but seems like ecu and immobiliser not getting powered up
Originally posted by matt cooke View PostGet the PCM tested, what went wrong with old starter? With ign off check pins 6 and 14 on the 16pin connector you should get 60ohms and with ignition on 2.5 volts on both of those lines.
how do i know which pin is which on diag socket
which side of bulk head mark
i presssume pass side
No, than you have no CAN, maybe its a broken wire or one of the ECU failt. Maybe you can look if you found the can tree of the ecu and look ift one of the others from the ring work. ore ift only one dosnt asnwer. than you must look for the wireing and look ift you have 30/15 and 31 in all places.
If all the modules are responding you should see 60ohms (ign off) if a module is down you will see 120ohms but if you have a quick look at the wiring loom and don't see anything then whip out the PCM and send it to ecu testing.com they will test it same day, but with no comms in your diagnostic machine it's usually the PCM or it's not powered up
