I'm having some problems with my BT stage 3 Escort it keeps going into limp mode (4000 rpm), seems to happen when water temp reaches 75-85 degrees.
Tried new MAP sensor, new blue water temp, new ACT sensor and different ignition module, no difference.
Also tried a different ECU and different chip (both P8 with same stage 3 setup though).
Tried reading off the flash fault codes, getting faults on TPS, MAP and another thing I couldnt quite figure out what was. But that makes no sense as it seems to be temperature related? And why would all of a sudden several sensors die?
So I tried fitting my ECU that SCS modified for Pectel monitor a few years ago, fitted the correct chip, wired up the monitor (4 wires) and all I get is a screen that lights up green. No text or anything working. Pins 8, 11, 20 and 27 from what I understand.
Any suggestions? Got the matches and a can of petrol ready
