ok this may or not make sense but ill do my best lol
i got another car loom to fit in my car but after investigation the coil plugs ignition amps have been cut out completely, knock sensor as well, a link wire from ignition live to coil wire and various other things
so im going back to my original loom as im still able to use it after i thought it was water damage but it turns out the central locking loom was knackerd lol
so with my loom i completely removed the engine loom, every wire from ecu plug which left me with a bunch of wires left over to join an uprated engine loom on
now this is my problem
so far the wires i have are
oil press light
oil pressure gauge for pod gauges
water temp gauge
rev counter
i have a black/red wire which im guessing is live as it has reds linked off it
black wire switched ignition
brown earth
then came the tricky part after testing wires i had one which went to the abs ecu, this was then found it went to a diagnostic port in engine loom so not needed, same with a red/brown for abs light but again goes to diagnostic
im now left with one wire
this goes to pin 85 of relay r8 in the fusebox, this relay is for lambda
now what do i do with it, this wire sends a signal from ecu to relay for lambda but ive removed my ecu connector as ive taken the loom out
do the after market looms come with this wire to power the relay up for the lambda? if so great if not im stuck
i know the after market looms have lambda connection, but how many wires, do they have 3 2 to ecu and one power or just 2 for ecu and i take power elsewhere, but it still leaves me with this wire from ecu to lambda relay
any suggestions on what to do?
oil press light
water temp gauge
rev counter
brown earth
