fuel swirl pot
HiOriginally posted by dlf3y View Postwill it be fine to do my fuel set up as in the picture
http://i607.photobucket.com/albums/t...pslldteg6a.jpg
It's close , but You should always have a filter after the high pressure 044 pump: before it goes to fuel rail
8 injectors, what spec you going for.
Interesting topic as I need to do the same but not on the cossie, if you don't mind could I ask how it would alter if an in tank pump wasn't there. Replace the filter you have in the diagram with a low pressure pump (if so any recommendations?) and move the filter to after the 044?
It does Paul,the one with the filter on itOriginally posted by RS 500 Registrar View Posthttp://i2.photobucket.com/albums/y34...T/P1000067.jpg
This is my set up
You drawing shows no feed pump to the swirl pot ???
