Is the car standard otherwise? What are your future plans if any? Most everyone will tell you unless you have an aftermarket engine management the standard turbo is probably your best bet. An upgraded turbo will require larger injectors, and some way of controlling them.
Wes
― Muhammad Ali
The turbo hasn`t failed but i noticed a little play in it, now i am not sure if it is faulty but getting it refreshed can only help and if fitting a 360 degree bearing helps then i am up for that. More preventative work than a neccesity
Try Ahmed Bayjoo at Grove garage, he used to do a hybrid version of the T25......had the convention on my old red ST !
It needed a piggy back chip and uprated fuel pump but no ECU and injector change required 😊
Apart from the compressor housing did it need uprated injectors/remap or anything?
Mines a standard car, had the T28 after the old one had a failed bearing, no increase in performance without other accompanying mods. At the time I was going to do the GGR 285 conversion, but since changed my mind - the turbo is there if I do plan any mods which is doubtful.
Mine has a GT3071 ball bearing turbo, RS500 style charge cooler, a ported head, larger injectors and a few other mods. Running on an aftermarket management...made 400hp/320tq at the wheels with 1.3 bar boost.
Before having it tuned I was expecting to have to run at least 1.6-1.9 bar in order to make decent power but there really is no need, the car is plenty fast as it is
― Muhammad Ali
