I need to use spacers on the front of my track car as I can't find the correct et to suit for a spare set of wets. I want to use 15mm spacers. I don't know anything about them. How you fit ie do you remove the original studs and insert cut down ones that bolt the spacer on? I'm not sure.. Any body using any? And anybody have any advice on manufacturer etc?
Spacers?
Spacers?
My Series 1 4x4 cosworth build
My 2wd WRC escos track car build
I get all my bits from www.mattlewismotorsport.co.uk/ -
Hubcentric spacers needed to bolt onto the hub, have a look at Marc Kinsey's fiesta threadsigpic
Iv got hub centric ones on mine, 30 or 35mm can't mind which, they bolt onto the hub using the original bolts then the spacers has the wheel bolt attached to it. I got mine from cossymad, were around £250 iirc.
I might have a set of 15mm ones in the garage mate, iv sent you a pm.
No mate. New yearMy Series 1 4x4 cosworth build
Simbo, replied mateMy Series 1 4x4 cosworth build
