Recently tested an engine fitted with a GTX3071, .82 exhaust, capped the boost mid range because of surge, but from about 5000 rpm with the duty cycle of the boost controller at 100% (waste gate shut, no leaks) the maximum boost we could get was 26 psi, from 6000rpm to 7000 pressure dropped to 24 psi, so I concluded that the turbo was not pumping enough air as with the original non-GTX turbo we had 32-33 psi from 4000-8000rpm.
Have I read the compressor map wrong as I thought the turbo will do 550 lbs/min at a pressure ratio of 3.
Am I missing something ?
Next test with GTX3076.
Steve
Steve
