Am i missing something?
  • Am i missing something?
    Hi can anyone help please
    Have i got the metal coolant pipe in the correct place?
    as i cant work out what to fix the bracket to
    I can't work the pic out. Doesn't the thermostat housing look the wrong way up or is it me?
      yes housing is wrong...
      I've had a few cosies where this pipe is just floating around, definitely not how ford intended.
      Bentley GT for the Week, Focus RS Mk2 for the weekends.
      Previous Owner Of M537 BSW and L7 KOS.
        must be an early 4x4 head off a saff maybe.
        I have the lump which the bolt screws into on my head.
          yes agreed there should be lump there to bolt to if everything was the way ford intended.
          although in pic thats a 2wd head not an early 4x4 one.
            I've had a different pipe to that on a couple of my cars in the past that doesn't have such a bent and people have put going up above the turbo. i think the pipe may be wrong? we need one of the experts to chime in and help you out.
              I think pipe is wrong
                the pipe maybe wrong for that hear however the pipe is the same as whats on my car iirc.
                  Thanks for the comments guys, yes i forgot to say the thermostat end housing was fitted like that when i bought it, i need to turn it, im sure it is a 4x4 head though as it hasn't got turbo brace lugs and the water ways look correct, i'll put a pic up of the underneath now
                      pipe
                      pipe is correct if you have bt escort pal, I would say the head is a 4x4 saff one, as dave says there is a boss on bt heads for that pipe to bolt to cheers
                        pics from my car I just took.
                          Thank you guys i thought i was going mad! lol
                          I'll have to make a bracket for it,
                          im guessing it is a saph 4x4 head as mine is a BT is there any other problems im going to come across? i hope not
                            if you use the lifting eye on the rear of the head, hang a bracket off that one and secure it from the rear end.
                              Great thanks mate!
