Anyone got a diagram of how it goes or do I even need it? Thanks
Petrol tank breather
I had to make my own as the standard one couldn't cope
You need one hole above the flap in the filler neck and run it to atmosfear I used a dash fitting
The one breather on top of the tank run to another dash fitting further down the filler neck not to far say 2inch just under the flap in the neck again
The only draw back with this is if you roll the car a little petrol will be coming out then again if I've rolled it it'll be the last of my worrys lol
Or you can buy one from demon tweaks I have one you can buy I used it but it wasn't enough flow for my set up it a billet anodised red one way valve with nice cloth type rubber pipe
