Can't beleive it the fucking car won't start
Tried first thing and couldn't get it started, I have a T6 ECU and it won't switch on and start the car if the power is under 10v I noticed it was under 10v when cranking on the stack so took the battery back to halfords.
They tested the battery and said running at 40% (what ever that meant) and replaced it, the only problem is they have a battery with the same terminals (cossie has the square versions) but the replacement battery which had round terminals came with adapters soI took it
Went to fit up the battery and the bracket on the positive side that has fuses built in wouldn't fit so i had to mod it..
Anyway got them all fitted up and the car is still just cranking over but not starting they weird thing is my pectel monitor is not comunicating with the the ECU either and is saying check cables etc
With Frasers help I checked I've got 12v at the injectors and 5v at the map sensor, the ecu hairbrush has 12v and ground so what the fuck is going on?
I've checked the cables on the battery and can't see that i've upset anything, problem is I have no idea whether the problem was deffo there before I changed the battery.
Left the new battery on charge for now just incase its something low voltage related
Seriously do not need this two days before Central
