EEC Diagnostics
  • EEC Diagnostics
    I know many of you have EEC Ecus,
    Do any of you have diagnostic tools that work well with them?
    I'm trying to get hold of something to use on EEC Escort and Fiesta Turbos, and just wondered if anyone had any feedback on some old school tools that work.
    I used to use an old snap on scanner at msd but they are hard to find now with the correct cable
    Regards James.
    www.autodynamix.co.uk
    www.shop.autodynamix.co.uk
    James you did mine I recall when you were at msd... and very effective it was too.. I seen one on ebay not long ago.. probably your best bet?
    Fizz
      We have the old FDS2000 Ford tool on the loft here, not sure if it still works
        Keep your eye out for an early generation "auto diagnostics" hand held, my dad kept theirs and it has the correct leads for many 90's diagnostic ports. There are a few tool selling pages on Facebook, worth popping a wanted advert on a couple.
          Thanks guys, i can see a few old snap on ones on eBay, but it was never the best, ill check out the others and see if they look better!
          Regards James.
            ForDiag, Czec version not the knock off.
            Tomas is english speaking as well. Just email him.
            http://forum.fordiag.cz/viewtopic.ph...5c626a3ce7fb4d
            Dowload the software and updates for free. Just need to purchase the accompanying hardware.
            http://forum.fordiag.cz/viewtopic.php?f=3&t=368
            https://m.youtube.com/channel/UC2fisgcqI89_pe-zyJibqGQ
            John
              cool!
              Regards James.
                Snap on
                I've got both old and newer souls pro early one with the complete lead kit as new still has screen film on it. Is the lead the 3 pin triangle and one that's oval with a flat bottom ish??
                Can't fault snap on fast loading and has most descriptions. I've got launch x431 pro very good at programming. Bosch kts always a faf. Autel ok but no discriptions of codes
                G scan pants.
                  Hello
                  I also use Fordiag from Tomas
                  greetings,
                  Ralf
                    James
                    Have you tried this on weber ecu`s ?
                    http://www.escortrscosworth.com/foru...=free+download
                      Weber stuff I'm sorted I have the IAW pro and emulator gear for them but not much for the eec, that's fordiag stuff looks perfect
                      Does it do fiesta turbos?
                      Regards James.
                        To be sure, ask Tomas about the Fiesta Turbo.
                        If the Fiesta turbo has DCL or OBD then I imagine it would work.
                        John
                          Fiesta is EEC like the small turbo Cos, same diagnostic ports as those.
                          Ive mailed him, i think ill buy it and see how it goes.
                          Regards James.
                            Same ports, then it should work.
                            I'm happy with mine, does what it says on the box. Had a couple bugs initially, but they were fixed after emailing Tomas.
                            I got rid of the OBD type connector on the device and fitted a DB-15 instead. Then used the tail from an elcheapo ABS sensor to connect to the Escos DCL plug.
                            John
