whats best and is internal or external required?
borg warner turbo for 500bhp
Originally posted by mark shead View PostThe turbo is good for 980c.
Have you tested them with full grpa als? The temp is not all, but also "explosions" in manifold that break shafts. Would be Nice to know how they handle it
I spoke to the chief designer of the efr range at sema last year and that's where my info comes from and no problem with ALS and also Julian Godfrey also uses a efr for his rally Cross engine tells you the same. ALS is fine for efr turbos.Originally posted by twin turbo View PostHave you tested them with full grpa als? The temp is not all, but also "explosions" in manifold that break shafts. Would be Nice to know how they handle it
Nice thanxOriginally posted by mark shead View PostI spoke to the chief designer of the efr range at sema last year and that's where my info comes from and no problem with ALS and also Julian Godfrey also uses a efr for his rally Cross engine tells you the same. ALS is fine for efr turbos.
