...GETTING THERE PICS ONCE WASHED.
...faults are now being sorted...abs i found a sensor wire in two...wasnt properly supported so the wheel caught it
slow puncture fixed...rear no/plate lights fixed..number plates changed...main beam fixed...boost gauge fixed...still a couple of things to do..ok spec for those interested:-
Sierra sapphire cosworth RWD (rainbird edition)
ENGINE:
200 block
wrc long studded
wrc multi layer head gasket
std pistons
std crank
std rods
uprated bolts
big wing sump
nick waples ported head
scs secret cams (probably std
adjustable cam pulleys
t4 turbo
rs500 drop alt bracket
rs500 intercooler
rs500 8 inj plenum
air injectors
3 bar map sensor
std modded airbox
std rad
water cooled powersteering pot
ally header tank
swirl pot
water injection
8 x 803 injectors
pectel super 8 ecu
live mapped
dyno'd at 515bhp
max boost 32psi
proven 180mph + car (mike show that stack dash pic for 0-60 and speed
12 position boost pot
breather system (not sure on make, looks complicated lol)
mongoose exhaust
TRANSMISSION
quaife big tooth box
quaife 3.9 rear diff
alcon 6 paddle clutch
SUSPENSION
leda adjustable coilovers
fully polybushed
front and rear strut brace
BRAKES
ap 6pot fronts with 356mm floating discs ds3000 pads
300mm rear discs std calipers with green stuff pads
WHEELS
18in new style comp mo's with 215/35 tyres
or
17in old style comp mo's with 235 rear 205 front tyres
BODY
4x4 shell (brand new 2003)
4x4 bonnet
arches rolled
carbon fibre numberplate surround rear
carbon fibre rear pillars
otherwise std
INSIDE
leather door cards
leather rear seat
recaro bucket seats up front
stack dash 8000rpm with lap timer showing oil pressure/oil temp/fuel pressure/coolant temp/fuel gauge warnings for all
apexi 2.5bar boost gauge with memory recall and warning
greddy exh temp gauge with memory recall and warning
greddy coolant temp gauge with memory recall and warning
greddy oil pressure gauge with memory recall and warning
..rainbird can add anything more
ENGINE:
200 block
wrc long studded
std pistons
std crank
std rods
uprated bolts
big wing sump
t4 turbo
rs500 intercooler
rs500 8 inj plenum
air injectors
3 bar map sensor
std modded airbox
std rad
ally header tank
swirl pot
water injection
8 x 803 injectors
pectel super 8 ecu
live mapped
dyno'd at 515bhp
max boost 32psi
mongoose exhaust
TRANSMISSION
SUSPENSION
fully polybushed
BRAKES
WHEELS
or
BODY
4x4 bonnet
arches rolled
otherwise std
INSIDE
leather door cards
leather rear seat
