would i gain torque to my engine by fiting a bd10 exhaust cam?
  • would i gain torque to my engine by fiting a bd10 exhaust cam?
    im just thinking ahead so i can get my engine exactly how i want it before i get it mapped.
    at the mo my spec is
    7:8:1cr, pocket pistons, long stud, wrc gasket.
    28mm inlet port 23.5 exhaust port, volcan head
    bd14 inlet cam standard exhaust cam. tt38 turbo
    rs500 cooler 60mm thick.
    i'm running a 4x4 bt inlet plenum with 10mm spacer
    and a 4x4 exhaust manifold.
    the power i want is a 450bhp 450lbft if possible??
    the map is very poor at the mo way to rich!!! and it did 443bhp at exactly 2bar with a really small spike at a dyno shoot out day,
    so i'm sure it will easly hit 450bhp if mapped right with a tad more boost which is fine..
    but its currently 390lbft this is where i want to push an improvement!! as you know its 2wd which i love!!
    i'm thinking with my spec go..
    2wd exhaust manifold, 2wd down tube extended(less bends in it)
    bd10 exhaust cam
    would i need to change my inlet manifold?
    hope not as i had to let one go to get mine running..long story..
    what do you guys think? i'm not keen on a gt30 as ive heard there none rebuild able..
    my personal opinion would be to get the 2wd manifold on there and have it mapped properly.
    i would then remove any thoughts in my brain about changing the exhaust cam to a BD10
      As kelv says, get a 2wd manifold and have it set up and mapped properly..............OR 2wd manifold and T4 it for 500bhp
      check my salethread
      would be mental rwd.
      Dan
        LOL @ Dan
          t4 and 500+ in 2wd is certainly lairy on the road
          BOSCH PARTS 07759984033
          INJECTOR CLEANING
            ive still not seen these turbo dampers for the small turbo head!
            whos car was the blue escos 1 or 2 places down from cossie crazys car at central day it had a scs engine 508bhp if i can remember rightly that had a lovely damper on a small turbo head
              Probably Dunc's car
                yes mine
                  I always read/heard it was better to use a BD10 Inlet cam and leave the standard exhaust cam in..
                  Surley more fuel and air gotta be a good thing. .
                    that engine looks amazing!! so where did the damper come from?
