5 bar MAP sensor and mounting block
  • 5 bar MAP sensor and mounting block
    anybody running them?
    Where do/did you mount them?
    Yes.
    No idea
      Helpful as ever Rich! I need to speak to you in the week!
        Thanks for the warning
        Have you got a mounting block off Martin ? If so got a pic
          Mount it up your arse Franco
          BOSCH PARTS 07759984033
          INJECTOR CLEANING
            something i need to address very soon.
            can they not be mounted on the standard MAP sensor bracket Jase?
              pass, and no pic Rich!
                pic of the 5bar?
                  pic of the 5bar?
                  No, the mounting block Kelv. Need to make one for my sensor.
                    Mine is on the strut brace, welded a bracket and bolted on
                    Work Hard, Play Harder
                      Incidently I have a 5bar instock
                      INJECTOR CLEANING
                        Phil can you tell me what is actually does ?
                          LOL, Noooo.
                          i want to see a pic of the 5 bar
                            Courtesy of Reyland:
                            Mounting Block
                            5 Bar MAP sensor
                              ...instead of guess mapping above 2 bar boost with a 3 bar the 5 bar can be mapped upto 4 bar boost correctly
                              INJECTOR CLEANING
