Whats my bhp?
    i know some t34 blowing more than 32 psi and holding that amount of pressure....btw they are modified...different comp wheel and shaft is balanced(ported shrouds) with cut back blades and journal bearings made from carbon,360 deg bearing....
    from what i saw they are still running but how much is it actually going to last that is question...i have similar set up on t34 .....
    on msd page i saw set up for black injectors on t34...it is supose to run 36 psi holding 32 and engine rev is up to 7600....scary....does anybody here have this set up and if so what is the power limit...
    also what turbo is the best for this amount of pressure/32 psi/....on greys or black injectors considering keeping standard cams.......
      Originally posted by escosgaz View Post
      my t34 hits 2.2 bar and holds 2 bar and gets a fair old thrashing , not sure how long it will last but wil upgrade if and wen it throws the towel in!, mine runs seimens 55lb injectors msd chip, antilag, launchcontrol, ported and polished head,wasted spark and was mapped recently by will and stu at msd, they estimated it 380-400bhp but until get it on martins dyno next year wont know for sure but goes well for road car.
      I would guess you are changing gear at 6500 rpm then . Rev it to 7000 and the turbo tails off to 26psi a smidge under 1.8 bar . However, this is severly pushing the turbo to it's limit, so as you say it will expire eventually.
      Back in the day before I knew any better and when I was running a peak of 2.4 bar, unsurprisingly I was getting through a turbo every three months .
      This is the graph for the power when the turbo was constantly lunching itself:
      Scarily it made a few more psi in the car, but seemed to love it .
        400lbft at 3500rpm must have been fun!!
          90mph wheelspin in fifth in the wet .
            what sort of time was it from 3500 to the limiter?? I remember when i got mine and it was running over 35psi it would get to just under 4krpm on full throttle then BANG its slammed round to the limiter in what felt like just over 1.5 secs and im like "WTF wheres 3rd gear" trying to realllllllly gently come off the limiter so i dont totally mince the box that cant have been normal
              msd done all my work and before they set my car up on the phone they said it wud run 36 psi and hold 32 psi but wen it was al set up and mapped by them it runs slightly under as they said didnt want me blowing turbo or box on way home as was fair journey for me. size of intercooler cud play a part on gain or loss of few psi. . .
              wen it goes will replace with t4 or gt30 and no doubt end up on the look out for a new gearbox shortly after. . . . but thats
                No idea. It was good enough for 170+mph though (3.36 gearing) and mid to high 12s quarters (if you got the launch right, which was far more tricky than the smaller turbine housing where it made 385bhp).
                  Mike 416bhp @ 6500 @ 25psi thats the scs T38 then, if not then that shows that dyno over reads.
                  BOSCH PARTS 07759984033
                  INJECTOR CLEANING
                    Originally posted by Mike Rainbird View Post
                    That will be an exagerated rolling road flywheel calculated figure, as T34s don't flow that much air, especially with standard cams.
                    I can tell you Mike, the guy who made the Turbo and ECU program is a Cosworth-Guru overhere. He had worked for Ford Motorsport, during the time they rallyed The Sierra and Escort Cosworth (he also prepared the Cosworths from Patrick Snijders).
                    He was also involved in the development from the Garret Turbo's they used, and the ECU programs they had.
                    My old saff 4x4 had 345,5 Bhp @ 5200 Rpm and 556,5 Nm @ 3840 Rpm (and NOT running lean at top end!!!)
                    The spec was:
                    - T03 Turbo (made by Gerry Knubben) 1.8 Bar (continiously) peak at 2,0 Bar
                    - L8 Ecu with program from Gerry Knubben
                    - K&N Group A filter
                    - Greens
                    - 3bar Map
                    - original intercooler
                    - original ignition (only Gr.A coil and Motorsport cables)
                    - Mongoose exhaust
                    - standard cams
                    - standard engine (only WRC gasket)
                    Car was driven hard, never missed a beat. Turbo still is one piece (after 60.000kms) without using oil or any play on the shaft. Engine already had done 200.000kms.
                    Don't ask me how he does it, but he can.
                    I know he uprated the turbo's with other shaft's and comp.wheels, fully balanced etc. He makes his own stuff for the turbo's. He has so much experince, I can't tell you.
                    If you want to contact him, I can give you his phone number Just PM or email me.
                    www.rallysportclassics.nl
                    specialized in Escort MK1 and MK2
                      A small vid
                      [ame="http://www.youtube.com/watch?v=Toj6QdIMkRY"]http://www.youtube.com/watch?v=Toj6QdIMkRY[/ame]
                      • #26
                        how do you work that out ? it was a t34 aswell iirc mikes never had a t38
                        • #27
                          If it is a stock engine with just a T34 380hp max based on a Dyno Dynamics RR.
                          • #28
                            if I recall correct it was lt blues and .55 housing
                            INJECTOR CLEANING
                            • #29
                              Phil,
                              No, it was a T34, but you have to remember that this is with a properly ported head and a pair of EXTREMELY high lift cams (11mm). These were so aggressive, that the standard lifters were mullered every 8000miles .
                              You also need to go to spec savers, as that made 418.8 bhp , but as I said, the turbo was so far outside it's designed speed range, that they went pop every 3 months. In the end Harvey stopped running the turbos so hard, and the power figures just tipped over the 400bhp mark. Obviously it is no good having high figures if the turbos don't last. However, you have to remember that this is all back in the mid to late 90s, when no-one knew how hard these turbos could be pushed until they were tested to the extreme.
                              • #30
                                What was the powerband like on that engine mike?
