birba dials
  • birba dials
    I may get for christmas, if i have been good. a set of these ( birba dials ). I am looking to get the set with the higher RPM, speedo reading and boost pressure. When i fit them will this mean that they will all be reading correctly. Or is is just for show.
    I would have thought you have to have them re calibrated
      Here is what I think u should do!get the dials in but dont put the glass/plastic front cover on firts,then hook it up whit all the connctors,speedo cable etc.let it sit not mounted behind the steering wheel and go for a test drive and the rpm,water,gas probably wont show right.So fill the car upp full whit gas and and adjust the the gas dial after that,same whit temp and rpm get it warm and adjust to what u usually have for running temp etc.its a little tricky.mabe there is a easier way but mine is fine now.
      WWW.COSWORTHCLUBSWEDEN.SE
      www.jospeed.se
        photos?-cost?-----cheeRS
          they will all read accurately still as long as you get the needles back on in the correct places,take some pics first and when you remove the stops for the needles make sure you let the needles settle before removing them,can be quite fiddly sometimes and may take some minor adjustments to get spot on
            they are a nice bit of kit, but they are a pain to fit, hours of tweeking the needles, mine are perfect now!! really pleased with them!!
              I've got the km/h ones in my car and the speedo is DEAD on with the GPS unit.
              Also the turboboost is pretty accurate aswell.
              Really chuffed with them.
              I've still got a new set of uprated mph ones for sale.
              cheeRS
              Speedy G. aka Geert
              http://www.ffocb.be/forum
              http://www.cossiepower.tk
              http://photobucket.com/albums/0703/Speedy_G/
              0-60mph in 4,8secs
              1/4mile in 13,12secs
                how much mate
                1/4 mile 9.52 @ 146mph so far
                  Originally posted by WENNY View Post
                  how much mate
                  Since they are brand new, the price is exactly the same as Birba direct which is 145,00 EUR without P&P.
                  145,00 EUR is currently £ 131,83 according to www.xe.com/ucc
                  Then on top of that P&P but I'll just charge what I've got to pay and I only send recorded and insured delivery.
                  There's already someone else who has first dibs on the set though.
                  He's letting me know by tomorrow if he takes them or not.
                  cheeRS
                  Speedy G. aka Geert
                  0-60mph in 4,8secs
