Longer Front Driveshaft?
  • Longer Front Driveshaft?
    Yes, more questions from me
    What car does the longer front, drivers side driveshaft that fits the Esc Cos come from? I think its a XR4x4??
    I fucked mine tonight doing my 2nd 4wd donut The first donut was 5mins before hand Won't be doing that a 3rd time
    GGR do them Fletch
      Thanks mate, will have a nosey on their site now
        http://cgi.ebay.co.uk/GGR773-Coswort...item5d2653d7b6
        Cheers mate, but £245??
        I know someone who works @ Ford's and can get them at very good discount Does anyone know which car the extended ones are from?
          I always thought it was xr4x4.
            it xr4x4
              Thanks lads, will get a price tomorrow
                try euro car parts i get mine from them i pay about 100 each for them
                  XR 4*4 drive shafts are too long lads. Talk to MR Rainbird.
                  xflow way to go!
                    John/Mike, can you explain please? I don't wanna order a new shaft and find out I'm gonna have problems. Cheers
                      As John correctly states, the XR4x4 ones are 25mm longer than standard, which is WAY too long (unless you are running 4° negative camber on the front ), and they will bind as they will end up touching the end of the hubs / inside of the diff.
                      The GGR ones are 10mm longer, which is perfect. However, be aware that the GGR ones come with aftermarket joints etc, which don't seem to last as long as the OE Ford ones....
                        As Mike points out, they are far to long.
                        I tried them several years ago and it was fookin' awfull, the car had no real feedback, was horrid to drive and a complete waste of money and effort.
                        Unless your running huge camber that warrants you using them, DONT!!
                          U might find you have another problem that has caused the joint to fail & its not the shaft at fault.
                            Thanks John, Mike and Kelv. Will get a price on a brand new genuine Ford, standard one Im not paying £245 for the GGR one. I will just not do anymore donuts
                              Ford want around the same money for a standard shaft as GGR charge for the modified one.
                              + an exchange unit.
