i want to install 2 breather ports in my rocker cover, one over each cam, i want to do them aeroquip, whats the best way about doing this?
i'm fed up with leaky rocker covers, ive tried every different method of sealing them up... ive done this job over 5 times now, from my findings if i drive the car under 2 bar boost they never seem to leak, as soon as the boost is over 2bar sudenly there leaking again, i'm convinced there is to much air pressure in the top of the engine...
my friends rb26 has twin breather set up standard he has no problems so i'm thinking there is a need for it.. surely with breathers at the top of the engine it should stop the air pressure build up which pushes the oil through the cam half moons seals... what aeroquip size is the oil breather system?
cheers
cheers
