Rocker cover breathers advice needed
    Dom, i get what you mean mate.
    not just the breather but the tank you have would have come with a kit to breathe from the cam cover, this complete kit i reffer to as the cheaper way, but you have done spot on by doing it from either side of the block anyhow.
    your oil leak from the rocker cover, have you tried renwing the gaskets, is both surfaces both clean and flush?
    i had a cam cover gasket powdercoated and it had some slight high points on the edges which didnt allow it to seal correctly, when the oil was up to temp and if the car was being used in anger then it had a tendancy to weep in a couple of places, i gave up in the end and had it blasted and started again with masking it off better.
      also (carrying on from kelvs), when you fit the new half moon seals and rocker cover seals, put a dab of sealer over each end of the half moon seal just so it completely seals that helps
        Tbh sounds like your engine is tired and breathing heavily with the problems you have put up.
        88 Sapphire RS Cosworth
        53 Focus RS
        05 Mondeo ST TDCI
          Iirc doms engine has been rebuilt before he got it so it shouldnt be that at fault
              Unless something isnt flat on the head which is causing the oil to get past, then i cannot see what else is wrong? Mine breathes for the exhaust side, inlet side and has a return to the sump and i dont have any problems and thats on a T4. Thats been used around track aswell and never had a problem.
              53 Focus RS
              05 Mondeo ST TDCI
                Im running a bailey breather tank (Mirror image) and Im pretty sure im breathing from both sides of the block and the cam cover.
                If your having problems mate then get one of these kits IMO Mine seems to be fine @ 491bhp and around 2 bar boost. Hopefully this will be a link to the kit I got.
                http://www.rapidford.co.uk/shop/prod...cm60g7901a3ho3
                  you do know you should never run a rocker breather on a ST !? cant remember the reason but i have read it before the block ones are fine on the ST
                    thanks for all your repleys i am breathing both sides of ther block and i'm returning below oil level, so it all good... my cam covers dont constantly leak it seems they last 3-4 months ish then go... im just fed up with drips on the floor... my old saph was the same...
                    the thing is, i think if it seals straight away then surely its right... thats why i'm thinking it must be presure related... i even put sealer under the front cam caps and everything..
                    i just want a permenat cure!! can you over breath an engine?
                    my friend is a ali metal fabricator and he said he could knock me up a custom breather with 4 breather ports and a return to sump and a atmosphere port... and make it look like a baileys just a tad bigger...
                    didnt the old rs500 touring cars have breathers in the cam cover?
                      Thought about getting one of the wrc breathers off Ad?
                      • #26
                        mines got a bailey breather and not had a gasket leak problem.(well it has now as ive taken the head off lol) but tbh i find that alot of the gaskets arent fitted correctly or the half moons.the get nipped,or arent seatted right and then leak.my saff never leaked and niethe rdoes the escort yet
                        • #27
                          AMEN dom dont be a tight arse get a PROPER breather
                          • #28
                            Originally posted by richyx View Post
                            you shouldnt get any pressure up there tbh as oil breathers are designed to release crank case pressure, as this pressure is caused by blow by past the rings, obviously more boost more blow by more crank case pressure, alls you should need is it to breath both sides of the block and a return to sump and id say one to atmosphere just to get rid of the pressure and mositure but not the oil
                            i wont ever breath from top of cam cover again as it just causedme more problems when going on full boost as it created a vacum and sucked the oil out my head and spat it into my catch tank
                            This is EXACTLY why you shouldn't breath from the cam cover - TOP advice .
                            Dom, DON'T DO IT!
                            WRC style, or take your cover off and have it checked to see if it is true. They can warp from the heat, so if this is the case, it will be the reason for the leak.
                            Also check where the leak is coming from to be sure you are curing a problem that is actually there (it could be leaking from a cam / pulley seal)?
