Originally posted by mark shead
View Post
Big Turbo vs Small Turbo
I agree with you Dave to an extent. I've grown up with the " Real Cossie" engine look and prefer the BT engine looks. I wouldn't go so far as to say the ST looks crap but not IMO as good as the BT. Bottom line is who cares, an ESCOS is an Escos in the end. Either engine can be tuned for big power if required with the right funds and modsOriginally posted by Davecos 4x4 View PostEveyone likes to see under the bonnet and see the cosworth engine cover, proper engine, not a st engine as they look crap.
so its down to looks and personal choice in the end. For me BT all the way
- 2 likes
So you've made up your mind then........Originally posted by Davecos 4x4 View PostEveyone likes to see under the bonnet and see the cosworth engine cover, proper engine, not a st engine as they look crap.
I think the ST cam and cambelt covers look a better integrated design. The BT covers look like they were designed by two different people who never coordinated.
Smithy,
I've weighed a few BT and ST head castings and cam covers. The ST cam/coil cover is magnesium/plastic and lighter than BT aluminium. The ST head casting is heavier than BT by the above amount. Make of it what you will.
BT uses a distributor, a lot of BT owners spend money getting around that.
Best turbos available are the EFR range. Real question is what size EFR you want. Drive the ST a bit before you decide what you want from it. Think about what type of driving you will do in it.
By all accounts Mark is the EFR B2 frame Cossie guru.
Edit:
The clutches are said to be good for 350hp and the boxes 380hp. So my perspective is choose a turbo accordingly or be ready to upgrade the drivetrain.Last edited by jsa; 09-09-2017, 04:27:35.Cheers
John
- 1 like
Thanks Mark, be good to speak to you to discuss options etc.Originally posted by mark shead View Post
That would be me.
appreaite your help
cheers
Great info, thank Jon really appreciate it mateOriginally posted by jsa View Post
Smithy,
Edit:
cheers
Again, cant thank you guys enough for all your help and advice - Such a great Forum!!!
What to look for? Mine is a 96 i think, but never checked how late in production it is... Think IT was a auralis blue original...Originally posted by phs84 View Post
mine too...should be nr. 7050/7145 with VIN SP93017..can you tell me yours?
