Can they not be adapted to run on the link ecu’s James or is it totally different data stream etc?
Escort engine monitor
Ok new update,
New Protocols are finished and tested, So we can now supply DTMs to work on the following ECU/Firmwares
L8 ECU on Aftermarket Pectel Firmware (Motorsport Developments etc works on these)
P8 ECU on Standard Firmware
P8 ECU Pectel Firmware (Data stream needs to be active in your Pectel based Chip)
P8 ECU IAW/MSD Firmware
So we can now cover pretty much all of the Data streaming Weber ECU options.
https://shop-autodynamix.co.uk/c/dtm-monitor
The Escort Cosworth clock mount fitment is really nice, with a proper click in unit.Last edited by James @ Auto Dynamix; 03-07-2019, 11:03:26.
