Soooo.....little update, I've now replaced the original ABS pump, which was definitely blown, with another. Now I can hear the pump running when the ignition is on but how long should it run for, because mine now doesn't seem to be stopping until you turn the ignition off. And the abs lights are still on. I just don't want to burn this pump out.
I haven't bled out the brakes again yet though, could that fix it do we think? Or is it still more likely to be an issue at the master cylinder/pump end?
